Vray3.4 打开后SketchUp就崩溃,请问怎么解决?
Results:
Error: Something went wrong while retrieving the system information from your computer. This may cause tests regarding System RAM, Windows version and/or graphics card memory to fail.
Error: Graphics card information is missing.
Success: System RAM requirement has been met!
Success: Operating system version requirement has been met!
Success: Graphics card OpenGL requirement has been met!
Success: Graphics card Hardware Acceleration requirement has been met!
The Checkup program found some errors (listed above). You may need to take some action in order to run SketchUp 2017.
See Help > Documentation for more information.
安装了SketchUp2017和Vray3.4,单独使用SketchUp没有任何问题,一打开Vray面板,SketchUp立马崩溃,查了百度,说有可能是显卡问题,使用SketchUp 2017 checkup检查,出现了以上报告,错误是图形卡信息丢失,但还是不知道怎么解决,有没有大佬知道怎么办?
yxc474011197
赞同来自: wdgt111
关闭su,把杀毒软件退出在重新打开试试
包贻清
赞同来自: zzzzzzzaa
3.60.03安装升级版,一打开su2015就崩溃
胜多负少符文
这个问题解决了吗,楼主
caomei456258
换一个版本的vray试试看吧
Liujiayanzi
同问
Alvs
我遇到这种情况,我重装了系统,就好了。。。不是SU问题,是vfs的问题,你也可以试试换个vfs
123zhong
把Vray3.4卸载,安装3.0的试试
