5、当错误信息中显示“Error: #<RGLoaderError: RubyEncoder Loader - Incompatible loader version. This protected script has been encoded with a newer version of RubyEncoder.”一般是安装了低版本的破解/加密插件,和SUAPP的Ruby版本不兼容,导致SUAPP无法正常启动,比如低版本的破解/加密Enscape。
解决方法:卸载干净、重新安装版本高一些的Enscape或其他低版本破解/加密插件;不想卸载它的话,建议在其他版本SketchUp上使用SUAPP。
载入文件 C:/Program Files Mine/WORK/Google/SUAPP/suapp/suapp_main.rb 时出错
Error: #<RGLoaderError: RubyEncoder Loader - Protected script C:/Program Files Mine/WORK/Google/SUAPP/suapp/suapp_main.rb header is broken. The file has been modified. Install the original unmodified file or contact the author of the script to get the original file. Error code [10]>
C:/Program Files Mine/WORK/Google/SUAPP/suapp/suapp_main.rb:9:in `RGLoader_load'
C:/Program Files Mine/WORK/Google/SUAPP/suapp/suapp_main.rb:9:in `<top (required)>'
C:/Program Files Mine/WORK/Google/SketchUp 2020/Tools/extensions.rb:197:in `require'
C:/Program Files Mine/WORK/Google/SketchUp 2020/Tools/extensions.rb:197:in `load'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/suapp_loader.rb:12:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/suapp_loader.rb:12:in `<top (required)>'
载入文件 C:/Program Files/SketchUp/SketchUp 2019/SUAPP/suapp/suapp_main.rb 时出错
Error: #<RGLoaderError: RubyEncoder Loader - Protected script C:/Program Files/SketchUp/SketchUp 2019/SUAPP/suapp/suapp_main.rb header is broken. The file has been modified. Install the original unmodified file or contact the author of the script to get the original file. Error code [10]>
C:/Program Files/SketchUp/SketchUp 2019/SUAPP/suapp/suapp_main.rb:9:in `RGLoader_load'
C:/Program Files/SketchUp/SketchUp 2019/SUAPP/suapp/suapp_main.rb:9:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `load'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/suapp_loader.rb:12:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/suapp_loader.rb:12:in `<top (required)>'
载入文件 C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb 时出错
Error: #<RGLoaderError: RubyEncoder Loader - Protected script C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb header is broken. The file has been modified. Install the original unmodified file or contact the author of the script to get the original file. Error code [10]>
C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb:9:in `RGLoader_load'
C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb:9:in `<top (required)>'
E:/SU2020/Tools/extensions.rb:197:in `require'
E:/SU2020/Tools/extensions.rb:197:in `load'
15 个回复
赞同来自: Coolle
1、是否将SketchUp安装在了中文路径下了,如“D:/设计软件/SketchUp”、”E:/草图”等等,这是非常错误的安装方式。
解决办法:
请卸载SketchUp,并重新安装SketchUp到非中文路径下,最好是SketchUp默认的安装目录。如:C:/Program Files/SketchUp/SketchUp2016
2、您的计算机系统用户名是否为中文?Windows系统用户名请勿取中文名,如果是,请查询更改为英文,或新建一个系统账号,或重装系统。(新建系统账号的方法)
3、当错误信息中有显示 “Error: 127:xxxx” 时,通常是因为曾安装或升级工行网银助手,请重新安装SUAPP客户端安装程序即可;
4、当错误信息中有显示 “Error:x:/xxxxxxx/registry.rb:319:in’QueryValue‘ ”,一般是由于使用过翻墙或网络代理导致,请使用腾讯电脑管家或360修复网络。
flywingwrh
赞同来自: xyaojue 、yineh
Error: C:/Program Files (x86)/SUAPP/suapp/suruby/gems/ams/lib/extension_manager.rb:342:in `block in require_all'
C:/Program Files (x86)/SUAPP/suapp/suruby/gems/ams/lib/extension_manager.rb:338:in `each'
C:/Program Files (x86)/SUAPP/suapp/suruby/gems/ams/lib/extension_manager.rb:338:in `require_all'
C:/Program Files (x86)/SUAPP/suapp/suruby/gems/ams/lib/ams_main.rb:148:in `<top (required)>'
E:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb:372:in `<encoded>'
C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb:7:in `RGLoader_load'
C:/Program Files (x86)/SUAPP/suapp/suapp_main.rb:7:in `<top (required)>'
E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `require'
E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `load'
C:/Users/26029/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/suapp_loader.rb:12:in `register_extension'
C:/Users/26029/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/suapp_loader.rb:12:in `<top (required)>'
skywalkermd
赞同来自: ZLJ001016 、dlg55
顺带提一句,这是最新版1.7.3,之前的1.7.1可以用,但是强行限制功能了。
guxingzuoban
寻风
请问这是怎么回事,SU为2018,路径也是英文的。
yineh
Error: #<LoadError: An exception occurred while loading lib, version 3.6.0s!\n\n5: \x{BEDC}\x{BEF8}\x{B7C3}\x{CECA}\x{A1A3} - C:/Users/admin/AppData/Local/Temp/lib/libraries/3.6.0s/win64/2.5/ams_lib.so>
C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require'
C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/suapp_loader.rb:12:in `register_extension'
C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/suapp_loader.rb:12:in `<top (required)>'
12347154747
Error: #<SyntaxError: C:/Program Files (x86)/SUAPP/suapp/suapp_lib.rb: get_local_var_idx: -1>
l779771758
coonybaby
yjzssj
张BL
SUAPP是1.7.3.0 显示已是最新版,没法更新
SU是21.0.339 64位
请问怎么解决?
JSBL_AD
喜多
hf17851412630
Error: #<NameError: uninitialized class variable @@Lan in TT::Plugins::CleanUp>
C:/Users/lenovo/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/tt_cleanup.rb:31:in `<module:CleanUp>'
C:/Users/lenovo/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/tt_cleanup.rb:15:in `<module:Plugins>'
C:/Users/lenovo/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/tt_cleanup.rb:14:in `<module:TT>'
C:/Users/lenovo/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/tt_cleanup.rb:13:in `<top (required)>'
大佬能帮我看看这个是什么问题吗?
快赶走乌云
