安装2014速图后,每次打开都出现下面的错误怎么办?
载入文件 auto_face.rb 时出错
Error: #<LoadError: cannot load such file -- whdialog>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/auto_face.rb:6:in `<top (required)>'
载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CB_Rot90/rot90.rb 时出错
Error: #<NameError: uninitialized constant Sutool>
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CB_Rot90/rot90.rb:42:in `<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CB_Rot90.rb:10:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CB_Rot90.rb:10:in `<top (required)>'
载入文件 combin_skps.rb 时出错
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/combin_skps.rb:13:in `<top (required)>'
载入文件 dynamic_snap_mlr_005_metric.rb 时出错
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/dynamic_snap_mlr_005_metric.rb:37:in `<top (required)>'
载入文件 Hidden2Layer.rb 时出错
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Hidden2Layer.rb:65:in `<top (required)>'
Error: #<TypeError: no implicit conversion of nil into String>
c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/dibac_cmd.rbs:218:in `small_icon='
c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/dibac_cmd.rbs:218:in `initialize'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/dibac_cmd.rbs:3648:in `new'
c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/dibac_cmd.rbs:3648:in `<main>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `eval'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:10:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:10:in `<module:Dibac_Extension>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:2:in `<module:Iscarnet_Extensions>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:1:in `<top (required)>'
载入文件 MAKE_FACES11.rb 时出错
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MAKE_FACES11.rb:130:in `<top (required)>'
载入文件 Push_z.rb 时出错
Error: #<NameError: undefined local variable or method `clear' for main:Object>
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Push_z.rb:63:in `<top (required)>'
载入文件 set_arc_segments.rb 时出错
Error: #<NameError: uninitialized constant Check_Sutool>
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/set_arc_segments.rb:57:in `<top (required)>'
Error: #<SyntaxError: c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/qsunshine/methods.rbs:88: syntax error, unexpected ',', expecting ')'
polygon_2_triangles (entity, tform ,head_string)
c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/qsunshine/methods.rbs:88: syntax error, unexpected ')', expecting '='>
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/qsunshine/main.rb:11:in `eval'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/qsunshine/main.rb:11:in `require'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/qsunshine/main.rb:11:in `<top (required)>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sunshine.rb:14:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sunshine.rb:14:in `<top (required)>'
载入文件 vfs.rb 时出错
Error: 126: ÕÒ²»µ½Ö¸¶¨µÄÄ£¿é¡£ - C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/RubyWinFunc.so
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:25:in `getWindowsASGVISFolder'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:45:in `getASGVISRubyFolder'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:50:in `setupPath'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:75:in `<top (required)>'
载入文件 Push_z.rb 时出错
载入文件 vfs.rb 时出错
