SketchUp安装完Vray3.404后无法启动怎么办?错误日志如下。
错误日志是这样的,希望能有人知道怎么回事
======== Starting GL ========
WGLUtils::IsExtensionFinderWindowClassRegistered: Class is not registered.
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAY1 : Radeon (TM) RX 470 Graphics : PT 3
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAY2 : Radeon (TM) RX 470 Graphics : PT 3
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAY3 : Radeon (TM) RX 470 Graphics : PT 3
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAY4 : Radeon (TM) RX 470 Graphics : PT 3
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAY5 : Radeon (TM) RX 470 Graphics : PT 3
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAY6 : Radeon (TM) RX 470 Graphics : PT 3
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAYV1 : RDPDD Chained DD : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAYV2 : RDP Encoder Mirror Driver : PT 1
WGLUtils::EnumerateAttachedDisplayDevices: \\.\DISPLAYV3 : RDP Reflector Display Driver : PT 1
WGLUtils::UtilsState::ctor: Max GPU perf is 3
GlInformation: Starting graphics capabilities tests.
WGLUtils::GetBestPixelFormat: Selected pixel format:
  Id: 11 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:0 FF:0
WGLUtils::CreateGLContext: Creating HGLRC with wglCreateContextAttribsARB.
GlInformation: GL renderer information:
  GL_VENDOR: ATI Technologies Inc.
GL_RENDERER: Radeon (TM) RX 470 Graphics
 GL_VERSION: 4.5.13492 Compatibility Profile Context 22.19.685.0
GlInformation: Compiling UberShader
GlInformation: Compiling OITSimpleDepthPeelLayerShader
GlInformation: Compiling OITSimpleDepthPeelLayerBlendShader
GlInformation: Compiling FaceShaderProgram
GlInformation: Compiling LineShaderProgram
GlInformation: Compiling SaawShaderProgram
GlInformation: All shaders compiled
GlInformation: Creating FBO
FrameBufferObject::Create(): Using renderbuffer storage.
GlInformation: All tests run
Checking GL version:>>4.5.13492 Compatibility Profile Context 22.19.685.0<<
OS Version:
CPU Specs:
Installed RAM:         0 MB
Adapter Type:
Adapter Description:
Adapter RAM:           0 MB
Installed Drivers:
Driver Version:
Resolution:
Bits Per Pixel:
Driver:
DPI scale factor:      1
OpenGL Extensions:
                                             GL_AMDX_debug_output
                                             GL_AMD_blend_minmax_factor
                                             GL_AMD_conservative_depth
                                             GL_AMD_debug_output
                                             GL_AMD_depth_clamp_separate
                                             GL_AMD_draw_buffers_blend
                                             GL_AMD_framebuffer_sample_positions
                                             GL_AMD_gcn_shader
                                             GL_AMD_gpu_shader_half_float
                                             GL_AMD_gpu_shader_half_float2
                                             GL_AMD_gpu_shader_int64
                                             GL_AMD_interleaved_elements
                                             GL_AMD_multi_draw_indirect
                                             GL_AMD_name_gen_delete
                                             GL_AMD_occlusion_query_event
                                             GL_AMD_performance_monitor
                                             GL_AMD_pinned_memory
                                             GL_AMD_query_buffer_object
                                             GL_AMD_sample_positions
                                             GL_AMD_seamless_cubemap_per_texture
                                             GL_AMD_shader_atomic_counter_ops
                                             GL_AMD_shader_stencil_export
                                             GL_AMD_shader_stencil_value_export
                                             GL_AMD_shader_trace
                                             GL_AMD_shader_trinary_minmax
                                             GL_AMD_sparse_texture
                                             GL_AMD_sparse_texture_pool
                                             GL_AMD_stencil_operation_extended
                                             GL_AMD_texture_cube_map_array
                                             GL_AMD_texture_texture4
                                             GL_AMD_transform_feedback3_lines_triangles
                                             GL_AMD_transform_feedback4
                                             GL_AMD_vertex_shader_layer
                                             GL_AMD_vertex_shader_viewport_index
                                             GL_ARB_ES2_compatibility
                                             GL_ARB_ES3_1_compatibility
                                             GL_ARB_ES3_compatibility
                                             GL_ARB_arrays_of_arrays
                                             GL_ARB_base_instance
                                             GL_ARB_bindless_texture
                                             GL_ARB_blend_func_extended
                                             GL_ARB_buffer_storage
                                             GL_ARB_clear_buffer_object
                                             GL_ARB_clear_texture
                                             GL_ARB_clip_control
                                             GL_ARB_color_buffer_float
                                             GL_ARB_compatibility
                                             GL_ARB_compressed_texture_pixel_storage
                                             GL_ARB_compute_shader
                                             GL_ARB_conditional_render_inverted
                                             GL_ARB_conservative_depth
                                             GL_ARB_copy_buffer
                                             GL_ARB_copy_image
                                             GL_ARB_cull_distance
                                             GL_ARB_debug_output
                                             GL_ARB_depth_buffer_float
                                             GL_ARB_depth_clamp
                                             GL_ARB_depth_texture
                                             GL_ARB_derivative_control
                                             GL_ARB_direct_state_access
                                             GL_ARB_draw_buffers
                                             GL_ARB_draw_buffers_blend
                                             GL_ARB_draw_elements_base_vertex
                                             GL_ARB_draw_indirect
                                             GL_ARB_draw_instanced
                                             GL_ARB_enhanced_layouts
                                             GL_ARB_explicit_attrib_location
                                             GL_ARB_explicit_uniform_location
                                             GL_ARB_fragment_coord_conventions
                                             GL_ARB_fragment_layer_viewport
                                             GL_ARB_fragment_program
                                             GL_ARB_fragment_program_shadow
                                             GL_ARB_fragment_shader
                                             GL_ARB_framebuffer_no_attachments
                                             GL_ARB_framebuffer_object
                                             GL_ARB_framebuffer_sRGB
                                             GL_ARB_geometry_shader4
                                             GL_ARB_get_program_binary
                                             GL_ARB_get_texture_sub_image
                                             GL_ARB_gl_spirv
                                             GL_ARB_gpu_shader5
                                             GL_ARB_gpu_shader_fp64
                                             GL_ARB_half_float_pixel
                                             GL_ARB_half_float_vertex
                                             GL_ARB_imaging
                                             GL_ARB_indirect_parameters
                                             GL_ARB_instanced_arrays
                                             GL_ARB_internalformat_query
                                             GL_ARB_internalformat_query2
                                             GL_ARB_invalidate_subdata
                                             GL_ARB_map_buffer_alignment
                                             GL_ARB_map_buffer_range
                                             GL_ARB_multi_bind
                                             GL_ARB_multi_draw_indirect
                                             GL_ARB_multisample
                                             GL_ARB_multitexture
                                             GL_ARB_occlusion_query
                                             GL_ARB_occlusion_query2
                                             GL_ARB_pipeline_statistics_query
                                             GL_ARB_pixel_buffer_object
                                             GL_ARB_point_parameters
                                             GL_ARB_point_sprite
                                             GL_ARB_program_interface_query
                                             GL_ARB_provoking_vertex
                                             GL_ARB_query_buffer_object
                                             GL_ARB_robust_buffer_access_behavior
                                             GL_ARB_sample_shading
                                             GL_ARB_sampler_objects
                                             GL_ARB_seamless_cube_map
                                             GL_ARB_seamless_cubemap_per_texture
                                             GL_ARB_separate_shader_objects
                                             GL_ARB_shader_atomic_counters
                                             GL_ARB_shader_ballot
                                             GL_ARB_shader_bit_encoding
                                             GL_ARB_shader_draw_parameters
                                             GL_ARB_shader_group_vote
                                             GL_ARB_shader_image_load_store
                                             GL_ARB_shader_image_size
                                             GL_ARB_shader_objects
                                             GL_ARB_shader_precision
                                             GL_ARB_shader_stencil_export
                                             GL_ARB_shader_storage_buffer_object
                                             GL_ARB_shader_subroutine
                                             GL_ARB_shader_texture_image_samples
                                             GL_ARB_shader_texture_lod
                                             GL_ARB_shader_viewport_layer_array
                                             GL_ARB_shading_language_100
                                             GL_ARB_shading_language_420pack
                                             GL_ARB_shading_language_packing
                                             GL_ARB_shadow
                                             GL_ARB_shadow_ambient
                                             GL_ARB_sparse_buffer
                                             GL_ARB_sparse_texture
                                             GL_ARB_stencil_texturing
                                             GL_ARB_sync
                                             GL_ARB_tessellation_shader
                                             GL_ARB_texture_barrier
                                             GL_ARB_texture_border_clamp
                                             GL_ARB_texture_buffer_object
                                             GL_ARB_texture_buffer_object_rgb32
                                             GL_ARB_texture_buffer_range
                                             GL_ARB_texture_compression
                                             GL_ARB_texture_compression_bptc
                                             GL_ARB_texture_compression_rgtc
                                             GL_ARB_texture_cube_map
                                             GL_ARB_texture_cube_map_array
                                             GL_ARB_texture_env_add
                                             GL_ARB_texture_env_combine
                                             GL_ARB_texture_env_crossbar
                                             GL_ARB_texture_env_dot3
                                             GL_ARB_texture_float
                                             GL_ARB_texture_gather
                                             GL_ARB_texture_mirror_clamp_to_edge
                                             GL_ARB_texture_mirrored_repeat
                                             GL_ARB_texture_multisample
                                             GL_ARB_texture_non_power_of_two
                                             GL_ARB_texture_query_levels
                                             GL_ARB_texture_query_lod
                                             GL_ARB_texture_rectangle
                                             GL_ARB_texture_rg
                                             GL_ARB_texture_rgb10_a2ui
                                             GL_ARB_texture_snorm
                                             GL_ARB_texture_stencil8
                                             GL_ARB_texture_storage
                                             GL_ARB_texture_storage_multisample
                                             GL_ARB_texture_swizzle
                                             GL_ARB_texture_view
                                             GL_ARB_timer_query
                                             GL_ARB_transform_feedback2
                                             GL_ARB_transform_feedback3
                                             GL_ARB_transform_feedback_instanced
                                             GL_ARB_transform_feedback_overflow_query
                                             GL_ARB_transpose_matrix
                                             GL_ARB_uniform_buffer_object
                                             GL_ARB_vertex_array_bgra
                                             GL_ARB_vertex_array_object
                                             GL_ARB_vertex_attrib_64bit
                                             GL_ARB_vertex_attrib_binding
                                             GL_ARB_vertex_buffer_object
                                             GL_ARB_vertex_program
                                             GL_ARB_vertex_shader
                                             GL_ARB_vertex_type_10f_11f_11f_rev
                                             GL_ARB_vertex_type_2_10_10_10_rev
                                             GL_ARB_viewport_array
                                             GL_ARB_window_pos
                                             GL_ATI_draw_buffers
                                             GL_ATI_envmap_bumpmap
                                             GL_ATI_fragment_shader
                                             GL_ATI_separate_stencil
                                             GL_ATI_texture_compression_3dc
                                             GL_ATI_texture_env_combine3
                                             GL_ATI_texture_float
                                             GL_ATI_texture_mirror_once
                                             GL_EXT_abgr
                                             GL_EXT_bgra
                                             GL_EXT_bindable_uniform
                                             GL_EXT_blend_color
                                             GL_EXT_blend_equation_separate
                                             GL_EXT_blend_func_separate
                                             GL_EXT_blend_minmax
                                             GL_EXT_blend_subtract
                                             GL_EXT_compiled_vertex_array
                                             GL_EXT_copy_buffer
                                             GL_EXT_copy_texture
                                             GL_EXT_depth_bounds_test
                                             GL_EXT_direct_state_access
                                             GL_EXT_draw_buffers2
                                             GL_EXT_draw_instanced
                                             GL_EXT_draw_range_elements
                                             GL_EXT_fog_coord
                                             GL_EXT_framebuffer_blit
                                             GL_EXT_framebuffer_multisample
                                             GL_EXT_framebuffer_object
                                             GL_EXT_framebuffer_sRGB
                                             GL_EXT_geometry_shader4
                                             GL_EXT_gpu_program_parameters
                                             GL_EXT_gpu_shader4
                                             GL_EXT_histogram
                                             GL_EXT_multi_draw_arrays
                                             GL_EXT_packed_depth_stencil
                                             GL_EXT_packed_float
                                             GL_EXT_packed_pixels
                                             GL_EXT_pixel_buffer_object
                                             GL_EXT_point_parameters
                                             GL_EXT_polygon_offset_clamp
                                             GL_EXT_provoking_vertex
                                             GL_EXT_rescale_normal
                                             GL_EXT_secondary_color
                                             GL_EXT_separate_specular_color
                                             GL_EXT_shader_image_load_store
                                             GL_EXT_shader_integer_mix
                                             GL_EXT_shadow_funcs
                                             GL_EXT_stencil_wrap
                                             GL_EXT_subtexture
                                             GL_EXT_texgen_reflection
                                             GL_EXT_texture3D
                                             GL_EXT_texture_array
                                             GL_EXT_texture_buffer_object
                                             GL_EXT_texture_compression_bptc
                                             GL_EXT_texture_compression_latc
                                             GL_EXT_texture_compression_rgtc
                                             GL_EXT_texture_compression_s3tc
                                             GL_EXT_texture_cube_map
                                             GL_EXT_texture_edge_clamp
                                             GL_EXT_texture_env_add
                                             GL_EXT_texture_env_combine
                                             GL_EXT_texture_env_dot3
                                             GL_EXT_texture_filter_anisotropic
                                             GL_EXT_texture_integer
                                             GL_EXT_texture_lod
                                             GL_EXT_texture_lod_bias
                                             GL_EXT_texture_mirror_clamp
                                             GL_EXT_texture_object
                                             GL_EXT_texture_rectangle
                                             GL_EXT_texture_sRGB
                                             GL_EXT_texture_sRGB_decode
                                             GL_EXT_texture_shared_exponent
                                             GL_EXT_texture_snorm
                                             GL_EXT_texture_storage
                                             GL_EXT_texture_swizzle
                                             GL_EXT_timer_query
                                             GL_EXT_transform_feedback
                                             GL_EXT_vertex_array
                                             GL_EXT_vertex_array_bgra
                                             GL_EXT_vertex_attrib_64bit
                                             GL_IBM_texture_mirrored_repeat
                                             GL_INTEL_fragment_shader_ordering
                                             GL_KHR_context_flush_control
                                             GL_KHR_debug
                                             GL_KHR_robust_buffer_access_behavior
                                             GL_KHR_robustness
                                             GL_KTX_buffer_region
                                             GL_NV_alpha_to_coverage_dither_control
                                             GL_NV_blend_square
                                             GL_NV_conditional_render
                                             GL_NV_copy_depth_to_color
                                             GL_NV_copy_image
                                             GL_NV_depth_buffer_float
                                             GL_NV_explicit_multisample
                                             GL_NV_float_buffer
                                             GL_NV_half_float
                                             GL_NV_primitive_restart
                                             GL_NV_texgen_reflection
                                             GL_NV_texture_barrier
                                             GL_OES_EGL_image
                                             GL_SGIS_generate_mipmap
                                             GL_SGIS_texture_edge_clamp
                                             GL_SGIS_texture_lod
                                             GL_SUN_multi_draw_arrays
                                             GL_WIN_swap_hint
                                             WGL_EXT_swap_control
GL_SHADER_STORAGE_BUFFER_BINDING:            0
GL_MAX_FRAMEBUFFER_WIDTH:                    16384
GL_MAX_FRAMEBUFFER_HEIGHT:                   16384
GL_MAX_FRAMEBUFFER_LAYERS:                   8192
GL_MAX_FRAMEBUFFER_SAMPLES:                  16
GL_MAX_RENDERBUFFER_SIZE:                    16384
GL_RENDERBUFFER_BINDING:                     0
GL_MAX_COMPUTE_UNIFORM_BLOCKS:               15
GL_MAX_COMPUTE_UNIFORM_COMPONENTS:           16384
GL_MAX_COMBINED_COMPUTE_UNIFORM_COMPONENTS:  2147483389
GL_MAX_COMBINED_FRAGMENT_UNIFORM_COMPONENTS: 2147483389
GL_MAX_COMBINED_GEOMETRY_UNIFORM_COMPONENTS: 2147483389
GL_MAX_COMBINED_UNIFORM_BLOCKS:              90
GL_MAX_COMBINED_VERTEX_UNIFORM_COMPONENTS:   2147483389
GL_MAX_FRAGMENT_UNIFORM_COMPONENTS:          16384
GL_MAX_FRAGMENT_UNIFORM_VECTORS:             4096
GL_MAX_FRAGMENT_UNIFORM_BLOCKS:              15
GL_MAX_GEOMETRY_UNIFORM_BLOCKS:              15
GL_MAX_GEOMETRY_UNIFORM_COMPONENTS:          16384
GL_MAX_UNIFORM_BUFFER_BINDINGS:              90
GL_MAX_UNIFORM_BLOCK_SIZE:                   572657868
GL_MAX_UNIFORM_LOCATIONS:                    4096
GL_MAX_VERTEX_UNIFORM_COMPONENTS:            16384
GL_MAX_VERTEX_UNIFORM_VECTORS:               4096
GL_MAX_VERTEX_UNIFORM_BLOCKS:                15
GL_MAX_TEXTURE_BUFFER_SIZE:                  268435456
GL_MAX_TEXTURE_SIZE:                         16384
Color buffer bits:                           24
Depth buffer bits:                           24
ValidateGraphicsPreferences: Starting up.
ValidateGraphicsSettings: Starting up.
ValidateGraphicsSettings: Desired settings values: MSAA: 4 FF: 1
  Id: 84 DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:4 FF:1
ValidateGraphicsSettings: Desired settings are okay.
ValidateGraphicsSettings: All done.
SaveGraphicsPreferences: Saving graphics preferences: MSAA: 4 FF: 1
ValidateGraphicsPreferences: All done.
File New
File New
>CBaseGLView::OnInitialUpdate
Entering CBaseGLView::InitializeOpenGL
WGLViewHelper::InitializeOpenGLForView: Got pixel format with attribs:
WGLViewHelper::InitializeOpenGLForView: Got context @3527eb0 error=0
IGLContext::InitializeContextState(): Stippled line width workaround applied (2.00).
IGLContext::InitializeContextState(): Keeping solid line width limit of 128.00.
IGLContext::InitializeContextState(): Keeping stipple line width limit of 2.00.
CBaseGLView::InitializeOpenGL: GL initialization succeeded
Tool(SelectionTool)
Loaded ruby file: C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb
Loaded ruby file: C:/Program Files/SketchUp/SketchUp 2017/Tools/langhandler.rb
Loaded ruby file: C:/Program Files/SketchUp/SketchUp 2017/Tools/sketchup.rb
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_advancedcameratools/actloader.rbe
Loaded ruby file: su_advancedcameratools.rb
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe
Loaded ruby file: su_dynamiccomponents.rb
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/geometryhelpers.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/meshhelpers.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/triangulatorutility.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/fromcontours.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/fromscratch.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/smoovetool.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/stamptool.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/drapetool2.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/detailtool.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/flipedgetool.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_sandbox/sandboxmenus.rbe
Loaded ruby file: su_sandbox.rb
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/main.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/core_object.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/date_helper.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/debug.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/exceptions.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/string_helper.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/tc_object.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/file.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/window.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/file_dialog.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/file_transfer.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/http_request_manager.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/observers.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/position_reference_tool.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/progress.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/reference_manager.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/session.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/sign_in_window.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/task_dialog.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/tc_dialog.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/view.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/viewer_dialog.rbe
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_trimble_connect/boot.rbe
Loaded ruby file: su_trimble_connect.rb
Loaded ruby file: c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/su_webtextures/webtextures_loader.rbe
Loaded ruby file: su_webtextures.rb
  • 请问楼主解决了吗,我也是这个问题,装了3.4 SU打开就报错
  • 请问解决了吗?也是安装了vray后,一打开就发送错误报告
